front foglights
  • Thread starter Thread starter Dragonvalk
Dragonvalk
I wish to wire front foglights to my GS, I have been told that there is a spare wire under the tank for accesorie, is this ture??
Dragon.
There is no spare plug that I am aware of, the BMW Adventure kit uses 2 Y connectors.
One takes a signal from the headlight plug under the tank, the other takes power by a fused connection from the power socket near the starter motor
Biker :D
relay
I wouldn't wire them direct, I guess it depends on the wattage.
I have a set of PIA's, 55W each running through a relay.
Wiring Diagram
There is a good wiring diagram on the board somewhere, someone will know where, I can't find it sorry, but if someone knows where it is and post a link it should solve Dragonvalks problem.
Wiring and Fitting Diagram
This should help with your Aux Lights problem, might be worth putting this in the Wisdom and Knowledge link Paul.
