Front mudguard extension
WindyChuffer
Londinium
Having done a few ride outs on my G650X, it needs a front mudguard extension for sure.
Now I dont fancy paying ~£76 for the ridiculously priced touratwat one.
Are there any sensible priced alternatives any of you lot know about?
You can probably pick up a generic acerbis front fender for about £15 from somewhere like racespec. It might take a little head scratching to make it fit (have a feeling it attaches under the yoke instead of in front of it), but shouldn't be to difficult.
HTH
Nathan
Here is some info..........quite a few people have done the mod of replacing the mudguard with Acerbis or UFO and also a couple of differrent KTM guards but you do get an unsightly gap between the guard and the headlight because it mounts underneath like nathan said.
http://www.advrider.com/forums/showpost.php?p=8630209&postcount=2225
Ian
That looks perfect, thanks.
Its funny, 'cos earlier tonight I was holding up a little bag to hold an innner tube/zip ties etc. to the front mudguard, and with the stock front fender there isn't enough space and the bag fouls the headlight. So this replacement fender method creates the perfect gap, and this is a good way of filling the gap... Coolio.
This is what I use... it's good
are the technik fenders easy to fit? and do they need the blanking plate as seen on the advrider thread?
cheers
Ive fitted the acerbis one, looks good and managed to source a bracket from Touratech, then fixed the lamp in position with some rubber straps. Ideally need to fabricate a bracket as seen on Advrider
Ah right fabricating brackets wouldn't be my strong point :p does anyone know if the advrider sells them or know of anyone else that makes them please?
Just seen on XC Farkles on ADVrider a guy who has replaced the OE mudguard with a Acerbis/KTM mudguard and fitted a tooltube horizontally in the space, looks good and are the type you can get either on here in vendors or from www.adventure-spec.com for around £16
for info the chap on advrider makes the technik brackets up and sales them for 25USD plus postage
Hi Frostyuk
Do you have a link for that bracket for sale, can,t seem to find it
hiya, there is no link, i sent him a pm on advrider on spec to see if he did and he does, he's making a batch this week:thumb2
I received this email from Stephan the chap in Germany making the sumpguards and case savers :thumb
Hi Mark,
I have read on your forum, that some people like to have another front mudguard!
I intend already for one year to make a adaption bracket for the front mudguard!
I will install at my Xchallenge a white KTM mud guard!
But that will need some time, because i must finish many sump guards first!
See The photos of the front mudguard i attached! (without the bracket, only for looking)
Greeting Stephan!
PS: instead of the yellow bracing, will take a black or blue one!
For info including postage to the uk the adv bracket is costing me 24ukp
Hi Rushy
yep ordered from Robert - id rwamf, he's the guy on the link from the xchallenge thread for the replacement front fender
Rgds
Ian
