Evening, well it came to the point were I had to remove the front engine cover as it was badly corroded. However I forgot to remove the bolt holding the cover to the bottom gear wheel. And pulled of its shaft which seems to be stopped from spinning on its self by some sort of woodruff key. I slipped it back on but I think I may have turned the bottom shaft slightly while trying to locate the wheel onto the shaft. The main question is does this need to be in a certain position relative to the top gear wheel above it as the teeth mesh together and the wheel I pulled off seems to be a sort of double gear sprung loaded in the centre. Any help is appreciated as I can't find anything to help online.
Bike is a 2006 1200gs.
