It's not my helmet because I don't get it on my RD.
That doesn't necessarily follow since the aerodynamics will differ between the two bikes.
Try wearing a different helmet on your GS.
Greg
, You guys may have missed the point!OMG, You guys may have missed the point!
When initially asked if he's tried moving the front wheel when on the centre stand he replied "No I havn't as the wheel doesn't spin at all unless forced"
If thats the case then ph4824 you need to get your bike back to the dealer sharpish, cos if the front wheel is binding, be it because of tyre rubbing or brakes etc, then you could be heading for a lot more problems. If you ride it in the wet it would be like braking in mid corner.
My advice, get it sorted quick.
Regards
GibGSA
Regarding front wheel, I bought a devise with rollers to rest the front wheel on in order to move it for cleaning, and that was fairly stiff. Certainly to stiff/tight to spin freely! Brake calipers will be touching at least. I tried to check the wheel bearings by checking the spindle tightness and it's a solid fit.
Regards
GibGSA
exactly wheel does not spin freely is a def worry id say?![]()
Sounds like he needs a fat assistant to press the rear end down.
Now where's he gonna find one of them on a GS forum ???![]()
We're good for something!
As usual, somebody is doing things the hard way first.
Instead of getting 1001 different answers on here, just take it to the feckin dealer and let us know what it really was. That`s what they are there for
They will sort the problem for you instead of you spending sleepless nights worrying about tyres, spindles or bearings for no reason. All this speculation will give you grey hair![]()
I havn't had a chance yet to lower back of bike to check as I will need my wife to help.
if the noise stops your front wheel has fallen off
