Fuel blockage
hitmanh
Cambridge, UK
Hi,
I seem to have myself a fuel blockage. I replaced the battery the other day and had starting issues (turns over but not catching). Further investigation shows spark at both plugs, pulled the injectors out and bugger all from the left hand injector. Pulling the inputs to the injectors shows no fuel getting to the left hand injector at all, while plenty to the right hand one. I had the tank off for fitting the new battery, but I can't see an hoses being squished and splitting the fuel QD connectors shows fuel is getting that far at least...
So, before having to spend a few hours pulling the fuel distributor/pressure valve thingy out of the bike, is there anything worth looking at?
Matt
You can gain access to the FPR and hoses in about 25 minutes if you don't have ABS. :D Try to leave the FPR in place and check the hoses first: They are push and pull whereupon the FPR is hammer and chisel (not literally) to remove.
I would take the tank off again and check everything you may have disturbed first.:thumb2
