- Joined
- Jul 23, 2004
- Messages
- 2,380
- Reaction score
- 128
02 single spark 1150GSA:
As with a few others here having problems with this model bike, I am at a loss trying to get it back on the road.
It has been over 18 months and still not properly sorted albeit £2K spent via an independent on parts and labour.
He was able to get it going so rode it home but, problems as before soon came back (engine backfiring, plugs sooting up).
All seems to work but it will not fire up.
I have replaced hall sensor unit, repaired frayed wiring, tried with another ECU to no avail.
Last week checked the tank internals, flushed out hoses, new strainer and filter.
Next is the fuel pressure regulator rail.
Is it possible to blow air through the two fuel lines going to the regulator and the injector connections to clear any debris, if any?
My problems initially started when I was riding looking for fuel with the fuel level lower than low, low. I have the adventure tank with the third under frame hose.
Injectors work (tested), I get a spark (visual).
Are they in sequence to fire up the motor?
Surely it cannot be out 180 degrees. I used a timing box to sync OT with the hall sensors.
