I was simply redistributing fuel from the right side of the tank to the left.
At least there was a good reason for it and you were not just being a daft bear
I had a new one fitted in July last year did 5,500 miles in the next 4 weeks, it failed in the 5th week, BMW parts man is guessing I thinkI have had three replacements, one lasted around 2000 miles the other 1350 miles, BMW will replace them FOC if within 2 years, I had my last one fitted by an independent, he never charged me fitting either and BMW sent the part direct to him, they do also require setting up on the computer thingy.
BMW parts man did say failures tend to be on bikes that are not used, if ridden regularly they are not prone to failure.
The fuel pump return flow drives a venturi (aka ejector) that sucks fuel from the RHS over to the left. The fuel gauge sitting on the left spends a long time around 1/2 full as the left is kept topped up. The level then falls quickly as the right side is now dry. All features of the tank shape.
The fuel strip is Mylar plastic with printed copper tracks. It all sits inside a hard plastic case. This is mine separated from the case and connecting wires.
The heater circuit show 37.6 ohm. The sensor is open circuit.
The end connection block is a very hard epoxy potting compound over the soldered connections. The strip looks fine even under a magnifier so presumably the failure is under that uber hard epoxy.
Wiggly line side (connecting wires snipped off)
Straight line side
Sent somehow.
The strip is fitted inside a plastic case so it can't flex in use.
I suspect it's failed under the epoxy potting compound possibly at the edge but it's the hardest resin I've come across. So even if we knew exactly what's gone wrong the potting isn't coming off to get at it.
Sent somehow.
Well i'm £220 lighter today![]()
Has anyone any experience of this device: http://hposkam.nl/en/bmw-r1200gs-a-tanklint-naar-vlotter-conversie/ If it works it looks like a permanent, although probably expensive, fix. I'm curious about how it would be calibrated but other than that it looks like a useful piece of kit.
I ordered one at the start of the week, just waiting for it to turn up.
I am also curious about calibration, I'll wait to see what is included with the instructions, if there is nothing I am going to ask Henk the question.
I haven't looked into whether the later float type has any calibration...I assume not.
If I have no information to the contrary I will run a calibration with the float at the lowest level (which I think is effectively what the dry fuel strip calibration is indicating).
Though it probably won't be any time soon because I do not have an actual float to replace the strip with yet!
