Fuel Gauge Problems
ianm00
Newport UK
I have a problem which has just started on my 1200GS. With a full tank of fuel the petrol gauge is varying between reading FULL or HALF FULL! The tank is filled to the brim!
It used to stay on full until about 100-120miles then drop to half so I know a problem has developed.
I found a similar thread discussing these problems for the 1150GS See here
Is there a similar connector problem for the 1200GS?
Ian
Same happened here after changing everything else fuel pump/guage cured the problem.
ianm00 said:
How was it fixed? Or what was the problem?
Ian
They usually try first to bend the gauge system in the tanks and clean some circuit under the tank. Sorry my english is not good enough to be technically precise.
It works but not for long. The second time you have the problem, they usually change the whole thing, pump included.
