- Joined
- Jul 23, 2004
- Messages
- 2,381
- Reaction score
- 128
This is the first round in getting my 2001 1150GSA on the road again.
Getting fuel to injectors so pump is working but, not through them!
Either all injectors blocked (OEM & 1200 mod Bosch injectors).
Using a continuity lightbulb test pen, with ignition on and in run position, I get no light to say any voltage showing at injector 2-pin connections.
Odds are it is an electrical issue.
I swopped round the fuel pump relay with the motronic one (same type)
Disconnected Lamba sensor, no change.
On my wiring schematic, yellow wire goes direct to the Motronic CU pin #27 (VERV). I have a spare control unit.
Black wire does a circuit around the relays and 02 sensor.
Fuses in underseat box are good.
As the fuel pump is working, the 4 pin tank connection should not be an issue.
Am I missing something?
Sent from my MI 9 using Tapatalk
