See below for fitment instructions:
1. On the original fuel strip, firstly remove the original strip from the plastic housing with the assistance of a flat bladed screwdriver to open up the plastic clip at the one end. Once this has been done, the sensor can be unplugged and the strip removed.
2. Now you can feed the new strip in to the black plastic housing. Push the strip in to the housing until you get to the sensor; push this in until it seats.
3. Snip the wires from the old fuel sensor so that you can then connect up to the exposed wires on the new fuel sensor, making use of the existing wiring connector. Connect the wires up, matching the colours as you go. We suggest soldering the wires for a good, solid connection. Cover the soldered connection with heat shrink.
4. Refit to the sensor to the bike, and calibrate just like the original sensor using a tool such as the Hex GS-911.
