fuel system
  • Thread starter Thread starter dave92029
dave92029
I'm outfitting my '05 R1200GS with a fuel cell and have two questions about the fuel system:
a) At what psi does the bike operate? I need to install a fuel pump from the fuel cell and understand that it should pump the fuel into the main fuel tank at a higher psi. Correct?
b) My bike it outfitted with a fuel cannister to recycle fuel vapors and overflow back into the main thank. I understand that there is a fuel line from the main tank for over flow going INTO the fuel cannister and an other fuel line RETURNING to the main fuel tank from the cannister. Correct?
If the above assumptions are correct, can I tap into the fuel line RETURNING from the fuel cannister into the main tank with a line from my fuel cell? Is there a one way valve already installed on this RETURN line from the fuel cannister?
Thank you in advance for any information or suggestions.
