Roymondo
Moving on from my issues with the bevel box drain plug - can anyone advise please the size and type of tool required to deal with the fuel tank rear mounting bolts on a 2011 GSA?
Replacing the air filter - what is on most other vehicles a fairly simple job - involves removing half a dozen body panels and (according to the Haynes BoL) raising the rear of the tank. I've actually managed to swap the filter without raising the tank, which is just as well as the same gorilla that munged the bevel box plug appears to have been let loose on the tank bolts. Now they certainly look like Torx - but my T30 bits are a sloppy fit while a T40 won't go in at all. The sockets look severely mangled. I'm assuming they're actually T35?
