Fuel tank breather blocked
Kritou
North West
My ‘07 RTP requires that the filler cap is opened every fifty miles or so to release a vacuum. The rubber pipe on top of the fuel pump assembly is clear and it’s plastic spigot won’t let me push anything through it
There is no charcoal cannister on this bike so short of replacing the whole and expensive FPA can any one suggest a way forward?
ps. if I let the fuel level fall too low the sides of the tank collapse pushing the base outwards which in turn interferes with the left stanchion and low speed steering
Can you take the filler cap off the tank and check the breather pipe between the cap and the fuel pump assembly that is inside the fuel tank also the breather itself.
It's also possible the blockage can be in the plastic spigot as you cannot push anything through it, have tried blowing through the end of the breather pipe that might free it.
OK, will take the filler cap off and investigate. Can I do any damage attaching a bicycle pump to the spigot?
Had the same problem yesterday and Williams Manchester spoke to me with a fix. The problem was low fuel on a really hot day and the gas pressure in the tank was preventing the cap from opening. The fix is to press the front of the cap when trying to open the latch and it works!
