Hello Friends, Can I pick your brains? I have recently removed the whole petrol cap assembly in order to check for any rust beneath. I found some, removed it, and painted the well with primer. Whilst there I tried to blow down both the hoses to ensure there is no blockage. One is clear but the other seems clogged solid. Should they both be clear, or is one of the tubes meant to be "blocked", perhaps connected to something, before exiting on the right hand side? Any help or guidance would be helpful. Incidentally, I fitted an "abdeckring" from an S1000RR in an attempt to reduce any further water going down into the well. Many thanks. RobA.
