Mike_swe Guest Jun 21, 2005 #1 My fuel tank is offset to the left, about 10mm. I'm going to remove the tank and try to fix it, but I wonder if anyone else have the same "problem" and have come up with a solution?
Tim Cullis Scotland lover UKGSer Subscriber Joined Oct 10, 2004 Messages 3,583 Reaction score 63 Location Putney, London and the Altiplano de Granada Jun 21, 2005 #2 You probably won't have to remove it, just loosen. There's a locating whatsit at the front on each side which the tank rests on. Tim
motozen Guest Jun 22, 2005 #3 Can you post pics of your mirrors? I saw you had very nice looking ones on a previous post. Who makes them? Thanks! (Sorry, can't say much about your fuel tank, as I"ve never taken mine off yet).
Guztav Guest Feb 14, 2006 #4 Tjenare Svensk! Jag har samma problem med tanken som du har haft på din 1200GS, fick du till det? Translate from swedish to english... Hello there Swede! I have the same problem with the fueltank that you had on your 1200GS, could you fix it?
Mouse Registered user Joined Jul 5, 2004 Messages 3,786 Reaction score 0 Location Cowering in a solipsistic funk Feb 14, 2006 #5 Hmm, is it actually the fuel tank that's offset or just the cover? You might be able to relocate the cover by using spacers or gently bending the mountings (of the metal part)/
