commandoallan
Hey All,
So I thought I had a faulty fuel strip, it was registering full but the fuel went down and the strip did not register this in any major way until I unexpectedly ran out of fuel which highlighted the issue.
I have just taken the fuel strip out and the LHS of the tank was half full, I calibrated the fuel strip correctly then put back in and started the bike back up. The readout went straight back to full which I knew was not correct so I took off the pump assembly again to reveal a full LHS tank with the RHS more or less empty.
Can anyone advise of the correct functionality of the fuel transfer from RHS to LHS and if there is a possible fi for this issue or should I make the change to the fuel level float I bought a year ago but did not need to fit as I previously zapped the fuel strip? It's been working fine for over a year but then this issue.
Need to put the bike back together tomorrow for work on Monday so would hope to have it sorted by then.
Many thanks.
Many thanks.
