Full exhaust system?
RichieS
Guildford , Surrey
Some of you may have been reading a thread started by Tobers about testing an 800 Triumph and a Super Ten, which i then hijacked and added my thoughts to, and added various other test rides.
Anyway, i have just tested an '11 plate GS which i thought was really good and one step above my '09 plate, but.......................what is the collective thought about putting a full Akro or Bos system on my '09?
Would it bring it near the newer GS in terms of power?
Has anyone tried both?
Ultimatley, whislt a full system is not cheap, it may well be cheaper than changing the bike ( which is a fully spec'ed SE).
Over to you Guys and Gals.
Richie
If you're going to do it, factor in the cost of dyno runs to establish the air/fuel ratios and more than likely an aftermarket device to allow the fuelling to be properly mapped on the dyno.
From my experience of fitting a full Remus system on both my previous '04 and '07 bikes, it will make a significant difference.
I have a 58 plate GSA with decat headeres bos end can PC +Custom map although greatly improved in terms of engine flexibility and smoothness it still dosnt match the extra grunt you get from the later 2010 dohc bikes save your pounds and get a dohc IMHO :cool:
