fredaroony
Thanks Jimbo. Does that mean that the various videos I’ve seen which advocate using the feed to the rear light are referring to earlier models of the GS? And the only suitable switched live on late GSs (1200 & 1250) is the feed to the 7.5 amp fuse in the fuse box under the front seat?
I’m surprised that I haven’t been able to find any advice anywhere on how to tap into a switched live on the GS without using posi-taps and the like, which damage the oe wiring, or expensive devices like the Ezcan. The only damage-free method seems to be the fuse-tap mentioned above. For my V-Strom (which has conventional non-CANBUS electrics) there’s a wealth of information in the various forums on methods of connecting into the bike's wiring without modifying it using a mini harness inserted between existing connectors in various locations around the bike.
I find this a little curious, you bought a new 1250, which is hardly cheap, and are concerned with damaging the wiring but wont buy a ezcan because it's too expensive. The EZCan is far more than a simple fuze block and also waterproof.
