Garmin 2610 power/audio cable
(RIP) Sugar Ray
North-East England
I've just bought the Garmin power/audio cable for my impending 2610, currently in the hands of UPS. The wires to connect up the power seem particularly 'spindly' (thin). Before I start chopping it up (it's about 7' long!), does anyone know if the cable sold in the motorcycle mounting kit (c/w bracket) is any different - it looks different on the web site. I didn't want the bracket as I'm getting the TT mount.
Regards,
Charles
The cable with the Garmin motorcycle cradle kit seems similar to your description.
I have the cable in front of me.
I have found other Garmin cables to be robust (even tho they are thin).
The individual cores are thin.
Like I said, I have one in front of me.
Charles:
The motorcycle cable is more substantial than the car cable - the outer covering is made of a different kind of rubber, meant to be more resistant to the elements, abrasion, UV, and grease and oil, as well as retaining flexibility during cold weather riding.
But, the gauge of the wires inside the motorcycle cord is identical to the those in the car cord. You would not want the individual wires to be any bigger - the voltages carried are small, and in the case of some of them, very low amperage - so any increase in wire gauge would cause transmission problems and an increase in power consumption.
I used a SP III cable for 70,000 km on my moto before changing it out to install a SP 2650 cable - had no problems with wire gauge size at all. If you are concerned about conductivity and making good connections, strip off more insulation than you need, double the bare wire back on itself about 3 times, and tin it with a soldering iron. This will give you something more substantial to attach to your electrical connector. But, be careful that you don't allow solder to wick up the wire (beyond the part you have stripped), otherwise, this increases the possibility that the wire may break later on due to fatigue, vibration, or impact.
If you are connecting the Garmin cable to an auxiliary bus bar on your moto, and want a more substantial wire gauge for the connection point, just splice the end of the Garmin wire to a short (few inches) section of heavier gauge wire, then use the heavier gauge wire for the connection point. But, keep the length of the heavier gauge wire as short as practically possible.
PanEuropean
Thanks for that guys - looks like the cable will be OK. Now all I need is the TT mount - they were out of stock on Friday, but hoping for some more in the next day or two. I felt lost riding around the Lakes today without my GPS :)
Regards.
Charles
How much is the TT mount? I've just upgraded to the 2610 and need to change the power cable and bracket, was going to get the Garmin bike kit, but was impressed with my old TT mount fopr the streetpilot 3.
The 'standard' one is £55 - lockable about £67, then the ones with extra shock-absorbing are about +£30 (for what appear to be thicker neoprene washers!!)
Regards,
Charles
charlie batty said:
...where's the cheapest place to get the 2610 power/audio cable in the UK?
E-mail Don at this site and ask him to send you a 010-10495-02 cable. They are $25 + tax + shipping each.
Probably quicker and cheaper than getting one in the UK.
Greg
PS I'll ring you later!
Charlie:
Just a hint for SP26xx moto installations - leave yourself a bit more slack than you think you need up at the GPSR end of the cable - because of the design of the Garmin, Touratech and RAM brackets, you need to first remove the GPSR from the bracket, then second disconnect the cable. This means you need more cable slack than with any of the previous GPSR's - on the other models, you could usually unplug the cable first, then remove the GPSR from the bracket second.
PanEuropean
