Garmin cable installation advice
  • Thread starter Thread starter triplesnip
triplesnip
I have a 2002 1150gs and want to install the power/audio cable permanently to the bike. Can I use loop connectors and attach direct to the battery or would that drain the battery .
Any advice would be greatly appreciated :confused:
you can connect direct to the battery, but be sure to use an in line fuse. i take the fuse out when gps is not to be used for a while.
smear some silicone grease on the connector to prevent oxidisation of the pins.
it won't drain the battery unless the gps unit is plugged in and switched on :)
Firstly hello and welcome to the site. Yes you can wire them directly and that's exactly how I had my Garmin wired to my 1150's with no battery issues.
Dave
Many thanks for your replies to my post ...just needed to know I was doing the right thing :thumb
