adamski49 said:
Are there any other ideas apart from those above to get the bloody data card reader to work with XP Pro?
It installs ok but a minute later XP rejects it saying 'unknown device'. I've tried 3 of the 6 USB ports and both with Mapsource running and not.
I'll try again in the morning as I'm deluding myself that it will be happy then.
Adam
Oh, merry xmas and happy new year by the way.
Try re-installing the driver.
Control Panel, System, Hardware, Device Manager, Garmin Devices, Garmin USB Data Card Programmer, Driver
Should be "grmn1200.sys" not signed by Garmin etc...
Either update or rollback. Alternatively try downloading again from Garmin web site and re-installing.
XP Home occaisonally gets its knickers in a twist as I switch the cdonnection between different hubs ( 1 hub USB2.0, 1 Hub USB1, 2 USB1 ports and two USD2 ports).
Normally tho it comes up with new hardware.
When this happens I just re-install the driver or point the "new hardware wizard" to one of the many of these drivers I have scattered on disk...
Alternatively restore back to the last checkpoint when you knew it was working...
