Sold Garmin Montana® 700i
mark71
Braintree, Essex
I have my Garmin 700i with Amps cradle and 12v power supply for sale, this has had little use and always looked after which anyone on here who knows me will contest to I always look after my kit.
This is the one that features in reach technology which allows you to communicate via satellite when out of mobile range which was a big yes when I was looking for one and saved me getting a separate inreach piece of equipment.
I would like £450 for this including the cradle and PSU posted anywhere within UK.
I am slimming down on equipment and found this surplus to what I need now
With routable mapping for roads and trails, the Montana® 710i GPS Handheld Device showcases advanced outdoor features in an impressive 5” format. The large touchscreen puts the outstanding usability at your fingertips, allowing you to navigate your way through the routable TopoActive Europe maps on or off-road with ease and clarity. Engineered to meet MIL-STD 810 for thermal, shock, water and vibration resistance, this powerful device offers up to 24 hours of adventure in GPS mode thanks to the lithium-ion battery.
Satellite Imagery gives you a clear perspective of the terrain around you, while active weather forecasts through the Garmin Connect app allow you to plan for the conditions. Navigate the great outdoors and track in more challenging environments than with GPS alone thanks to access to GPS and GALILEO satellite networks. The unit is powered by an internal, rechargeable lithium-ion battery pack which provides up to 24 hours of battery life in GPS mode – perfect for all-day excursions and multi-day treks.
Features
  • Advanced GPS Handheld Touchscreen Unit
  • Glove-friendly large 5” touchscreen colour display
  • Routable TopoActive Europe maps
  • inReach® Satellite Compatible Technology
  • Meets MIL-STD 810 for thermal, shock, water and vibration
  • Clear perspective from Satellite Imagery to see photo-realistic views and create waypoints based on landmarks
  • ABC sensors including an altimeter for elevation data, barometer to monitor weather and 3-axis electronic compass
  • Active weather – use cellular connectivity to access up-to-date Active Weather forecasts through the Garmin Connect app
  • Multiple GPS and GALILEO networks extend your exploration zones
  • 24 hours of lithium-ion battery life in GPS mode
  • Durable, water-resistant body tested to US military standards
  • Dog Tracking – syncs with compatible Astro® or Alpha® series handhelds (sold separately) to help track dogs in the field
  • Wikiloc Trails – Preloaded app allows you to download user-generated trails for hiking and cycling
  • Variety of Montana handheld-compatible mounts are sold separately
  • LiveTrack feature lets you wirelessly connect your device with other compatible Garmin GPS users, so they can follow your tracks, routes, waypoints and adventures
  • Expedition mode is an ultralow power GPS reference to keep Montana tracking for a week or more between recharges
Technical Specification
  • Battery: Up to 24 hours of battery life in GPS mode
  • Dimensions: 9.19cm x 18.30cm x 3.27cm
  • Display size: 6.48cm x 10.80cm (5” diagonal)
  • Display resolution: 480 x 800 pixels
  • Display type: WVGA transflective, dual orientation
  • Lens: Chemically strengthened glass
  • Weight: 410g with included lithium-ion battery pack
  • Battery life: 24 hours in GPS Mode, 440 hours in Expedition Mode
  • Water rating: IPX7
  • High-sensitivity receiver
  • Charging: USB-C
  • Memory: 32GB (user space varies based on included mapping)
  • In the box: Montana® 710i, lithium-ion battery pack, USB-C to USB-C cable, documentation
