Timolgra reformed Joined Sep 8, 2002 Messages 33,919 Reaction score 34 Location ..... May 12, 2007 #1 I'm thinking of changing to a Garmin 2610 from my old Street Pilot III does the Touratech mount fit both I presume it uses the same 4 pin plug? Will it also fit a 276C, I appreciate the plug is different? ta
Hman Registered user Joined Mar 11, 2006 Messages 166 Reaction score 0 Location duglay May 13, 2007 #2 timolgra said: I'm thinking of changing to a Garmin 2610 from my old Street Pilot III does the Touratech mount fit both I presume it uses the same 4 pin plug? Will it also fit a 276C, I appreciate the plug is different? ta Click to expand... no, both units use (2610 & 276) different mounts from the sp111. (and power plugs) Hman
Timolgra reformed Joined Sep 8, 2002 Messages 33,919 Reaction score 34 Location ..... May 13, 2007 #3 Okey dokey thanks, perhaps I'll persist with the SP III
Garry H Well-known member UKGSer Subscriber Joined May 16, 2002 Messages 1,297 Reaction score 68 Location Midlands May 13, 2007 #4 Get youself a 276c Tim you know it makes sense You will never need paper maps again Unless you forget your memory card Attachments 276 (Large).JPG 110.3 KB · Views: 140
Timolgra reformed Joined Sep 8, 2002 Messages 33,919 Reaction score 34 Location ..... May 13, 2007 #5 Garry H said: Get youself a 276c Tim you know it makes sense You will never need paper maps again Unless you forget your memory card Click to expand... feck me I was just about to phone you
