For Sale garmin zumo 340lm
oly
Cockermouth Cumbria
garmin zumo 340lm
just the unit and a usb charger
unit works fine , i updated it with the latest maps and it will only load south europe onto the card, reading up on it garmin dont support it and apparently you have to contact garmin to get the correct maps on it .
i can’t be bothered , so it’s available if someone either wants to put the uk back on it or faff around with garmin to get euro maps ?
£50 posted sound about right ?
garmin zumo 340lm
Hi Oly I have two of these well.... a 340 and 390. They don't take all of the European mapping on the unit but will with a FAT32 formatted SD card which is between 8 and 32 GB (nothing bigger) they will, just select the option of putting the maps on the card during install on Garmin Express. Also if you don't want to put a card in and have all of Europe you can select which European region you want during the Garmin Express install. Great little units and better for following routes than my Zumo XT. I have one of those as well!!. Failing that a great little unit for someone. The connection leads and holders are still available from Garmin and it uses Garmin NTU mapping the same as the Zumo XT and XT2
