Baza 07 Active member UKGSer Subscriber Joined Aug 29, 2020 Messages 406 Reaction score 66 Location Wirral Merseyside Apr 16, 2024 #1 Hi folks i bought a Touratech cradle which used to house a Zumo 660,the Q is would the Zumo 350LM fit the cradle,,,,,,Cheers Baza
Baza 07 Active member UKGSer Subscriber Joined Aug 29, 2020 Messages 406 Reaction score 66 Location Wirral Merseyside Apr 16, 2024 #2 Bump as i'm on a mission
wessie Registered user Joined Jan 8, 2002 Messages 20,321 Reaction score 8,576 Location Welshpool Apr 16, 2024 #3 No, the 660 uses the same cradle as the BMW Nav 4, 5 or 6 Zumo 3xx uses the cradle with just 2 pins
Baza 07 Active member UKGSer Subscriber Joined Aug 29, 2020 Messages 406 Reaction score 66 Location Wirral Merseyside Apr 16, 2024 #4 wessie said: No, the 660 uses the same cradle as the BMW Nav 4, 5 or 6 Zumo 3xx uses the cradle with just 2 pins Click to expand... Cheers Wessie,i'm not to bother about the pin side of things,as i'll be using a wire to a USB,its just if the bugga will fit in the cradle and lock,,,,,,,,,,,,,Cheers Baza
