Wanted Garmin zumo xt mount and power supply
pieter.oneill
Staffordshire
Hi all, just wondered if anyone had a spare or not required anymore garmin zumo xt satnav mount and power cable i could buy. Its only the bit where it clips into that i need i have all the rest of the stuff to mount it to my second bike. Cheers all
Sportsbikeshop have them in stock. Power cable £34.99, mount £17.99
Yeah, i saw them i may indeed just end up going back and picking them up. I did think £53.00 was quite steep for what essentially a piece of plastic and a cable, does seem fairly robust though, i thought id check someone didn't have an old one knocking around for twenty quid or so, im not desperate so ill have a gander on the bay and when i need one if so ill just go grab a new one. cheers
I have one of these with the attachment to fix it to the nav bar on a GS, it has the connector for the XT and a GS power adapter as well. I can send you some pics tomorrow if you are interested, I am looking £80 posted.
Regards
Norms
Cheers norm but i have all the mounts on my gs ready but they only give you one powered base in the xt box, my rt ive got a custom mount so had all the mounting gear left over. No worries not in any panic anyhow 👍
I have 2 new unused GARMIN XT2 mounts including the wiring and Ram mount as per the photos see attached £35.00 each plus postage.
I have 2 new unused GARMIN XT2 mounts including the wiring and Ram mount as per the photos see attached. I think the XT / XT2 use the same mount. £35.00 each plus postage.
Hey pal, that would have been spot on, except allthough they technically fit, the power supply to the xt is 5v and has a little box on the wiring to reduce to the 5v where as the xt2 is powered by direct 12v from the battery. But at least i learnt something new or id have probably blown my unit up 😂👍
Are you sure the xt2 is 12v? I’ve been using mine with XT wiring/holder
Hey Guys, i never had time to look into it in depth before they sold i just read a quick statement when i searched to see they were compatible i will look more into it when home. Glad you sold them Wanderer that was quick the power of the forums. haha cheers
