Sold GARMIN ZUMO XT & XT2 SECURITY LOCK BY MOTOPUMPS £30
no01bignige
Member
Verwood,Dorset.
For the Garmin Zumo XT, XT2 and Garmin Tread 5.5 and Tread 2 (6” Powersports)GPS Units ***Note - If you have purchased the Group Ride Radio add on module, the antenna interferes with the locking mechanism***Get peace of mind for your GPS investment!The MotoPumps® Security Lock installs between the Garmin Zumo powered cradle and your chosen GPS mount that attaches to your motorcycle. The lock is thin enough that it allows you to re-use the stock mounting hardware included with your GPS mount. The security pin locks the GPS in place on the powered cradle that came with your Zumo XT and prevents the release plunger from being depressed. Installation takes a matter of minutes on any GPS mount compatible with the Garmin Zumo XT, XT2, Tread (5.5) and Tread 2 Powersports (6”).A few quick turns of the 304 stainless steel security pin with it’s proprietary security key and you can lock or unlock your GPS. The billet 6061 aluminum plate is light, robust, corrosion resistant and unobtrusive.The Garmin Zumo XT Security Lock by MotoPumps® includes the security lock, security pin and two security keys. Extra pins and keys are available as options in the pull down menu.The Zumo XT is a great GPS from Garmin, worlds ahead of the previous generation Zumo models, but Garmin left off an important feature. Earlier Zumos had a security or anti-tamper screw that made it harder for someone to snatch your GPS when left on the bike during a stop. Garmin bothered with no such feature on the Zumo XT.When I first got the XT, a couple of things stood out. The screen- awesome! So much better than the 450/550, 395/6, 590 and 660/665 models.... The early production Garmin powered cradle latch did not instill confidence, but is actually quite secure in practice. The newest ones engage with a solid click. Nice. The bad news, there is no lock or anti-tamper device as delivered by Garmin.Looking around at locking mounts and security locks on the market and there are only a couple of choices -- one is HUGE and HEAVY! It actually weighs almost twice as much as the GPS alone. One is just a bit clunky, uses a traditional key and is unfortunately hard to come by in the US. One is pretty small, but ungodly expensive.The design goal for us is a security lock that makes it hard to steal the GPS when you leave it on bike for a few minutes while you get gas, or eat lunch or take a leak... It needs to be sleek, elegant, light, robust and unobtrusive. It needs to be easy and quick to use and not break the bank. It needs to work with any mount that fits the Garmin XT powered Motorcycle AMPS pattern base.
Pick up only.
