Gear lever bush
fayeslane
Albury, NSW, Australia
My R100GSPD has a needle roller bearing in the gear lever pivot. I replaced it but the new one ($$$) came with the same amount of slop in it as the old one :confused: Wear in the retaining bolt I suppose. Has anyone used a bush of any description to replace the bearing and can you buy one of the shelf? Thought I would ask before I go to the lathe and reduce a large useful piece of material to a small useless piece of material and a lot of profanity :blast :D
i don't think they were a bearing from new, mine wasn't. just a bush.
I did machine up a new one and it had to be very neat on the size to work, just 0.1 mm makes it feel loose
I thought that's why we bought lathes :confused:
I have a box full of those under my lathe :D
That's interesting Rob -I was wondering why you would stick a needle roller on the bottom of a bike right in amongst the dust and shit :confused:
Might have a crack at making a bush but 0.1 mm is daunting when I usually work on getting to within a mm, give or take :eek
What material do you reckon I should use -steel, aluminium, nylon, teflon ?
I would be tempted to use oilite if you can get that in Aus but depending on the sizes you might be able to get one of the shelf from a bearing supplier
Cheers C'n'C
Could just be availability, and cost.
When I needed a small end bush for my B44 I was quoted $60- probably because it fits a Goldie too. Would have needed reaming after fitting .
It is a standard 3/4 x 1 x 1" long bush so I dropped into my friendly bearing supplier to see what was available in stock bushes.
Cheapest option was a Torrington crowded needle roller for less than $10-, and it didnt need reaming after it was fitted either.
He had bush stock, but only in 450 mm lengths and over $100-
And my G/S hasa sloppy roller too, fitting an O ring both ends helps a bit.
This may be a little crude for some of you engineering experts but I found the spigot on the frame was either 10 or 12 mm (can't remember) and the hole in the gearlever was 2mm larger. French copper plumbing pipe comes in 10/12/14/16/18/20/22 OD all with a 1mm wall thickness so I just cut a suitable length which turned out to be a tap in fit in the gearlever (interference, I believe its called) and a snug sliding fit on the spigot with a bit of grease. Been working fine for a few kmiles but if it start to get sloppy again I'll just make another. Little risk of it wearing the steel parts.
THE BUSH IS A STANDARD SIZE 12MM BORE 18MM Plain Oilite Bushes - Metric ISO2795 IS THE TYPE OF BUSH YOU SHOULD BE LOOKING FOR THESE ARE ABOUT £5.00 IN THE UK SO SHOULD BE CHEAPER IN AUS
Off to the bearing shop this morning armed with this info -thank you for the heads up. It'll be a bloody first if it's cheaper here :D
Oillite type bush 12mm x 18mm x 25mm long fits like a thumb in a bum and has reduced the slop in the gear shift by about 90%. Still a little play in the ball joints. Available from my local SKF bearing shop for $12 bucks. :thumb2
Thanks all for your input, should be able to find most of the gears now :D
