For Sale Gear/oil filler caps
OldCroc
Welton nr Lincoln, England
These would fit 1150 and 1200s and possibly others as far as I am aware. Please make sure you check.
There are three items. The first two are 18mm diameter thread and both have crush washers.
The third is a replacement oil filler cap which uses the same tool for fitting/removal as the oem tool. This does not have the rubber washer but you should be able to use the one you replace.
£6 posted to Uk. Ppal f&f.
