gear selector problems
Phil Reynolds
South Northants
I'm having trouble changing down through the gears on my GS. It's done 15000 miles and you can change up as normal, but when you try to change down again, it feels like the pedal is in first gear as it won't travel any further.
Has anyone else had this problem and was it fixed easily, or was it a gearbox stripdown job?:(
Check the Gear selector mechanism,attached to the gearchange.
The pin and clip have probably fallen off.
Quite common.
