Gear shift assembly
Rugged Path
The Honourable.
Wybunbury, Cheshire East, England, EU
I tried using the www.partsfinder.com microfiche online to look up some parts but, the picture is badly pixelated and there is no part no. listing box.
Is there a better online source for viewing?
Reason is, my gear shift assembly on the 2010 Ultra Classic is very loose. All visible parts are tight so, the problem is from the gear shaft going into the gearbox. A video I saw a while back said it may be the O’ring seal worn. Similar problem a while back found a shaft one piece shell bearing cracked lengthways. Maybe it has occurred again .
A big job if you don’t have the correct tools.
Patria o Muerte
The gear arm normally wears / the spline is hardened and rarely wears... check your model year as they modified the inner primary design to enable it to be removed - on my Evo - the whole primary has to come off.
