what have i done
Hello all.. I usually lurk in the shadows but I am hoping for some advice regarding my gs1150.
A few weeks ago i decided to take a few bits off for cleaning and a maintenance... Well things soon ended in a full dismantle (my garage looks like a haynes manual photo-shoot... a messy one, its now a full restoration..
Problems encountered so far
Corroded/snapped bolts... I am now fully trained up with helicoil inserts and after 3 hours with a Dremel removing a snapped "easy out" I will never use one on a rusty stud again!
The coating inside my tank is coming off in big pieces,, Currently the tank (minus the pump/filter) is filled with a caustic solution to get it all off.
Just when I thought I was ready to drop everything in for blasting (soda for engine, grit for the black bits) the bolt holding the swing arm to the gearbox would not come out... at least not without damaging the threads.. I have sourced a new bolt but cannot find a suitable helicoil.. M27x1.25 anybody know of a supplier?
I am currently investigating having a "top hat" shaped bush made at a local engineering firm to accept the new bolt. but I am open to any suggestions.. obviously changing the box is a last resort!
many thanks in anticipation.
