I'm short...
this is just something I do, but should in no way be read as instructions or advice and you should always get an adult to assist.
1. Approach parked bike in gear on sidestand.
2. Grab handlebars bars with 2 fingers holding front brake
3. Apply full right lock
4. Push bike upright
5. Side stand up. Airhead stands will swing up when bike gets upright
6. Pull in clutch
7. Start bike
8. Swing right foot to accross bike to R/H footpeg
For Americans reading this:
9. While continuing to apply both front and rear brakes and continuing to keep the clutch lever pulled in, align handlebars with your intended direction of travel
10. If it is safe to do so, operate brakes, clutch, gears and throttle in your preferred sequential order to ensure smooth forward progress until you complete your journey while being mindful of other highway users and the regulations that will apply to you as a fellow highway user.
11. On completion of your journey to your chosen destination, apart from step 10, attempt most of the above steps in reverse order until your motorcycle is at the position as described in step 1. If this proves troublesome, the motorcycle can be ridden slowly in tight circles around the person you wished to see at your chosen destination. Conversation, transactions or other business can be attempted but the other party should refrain from interferring with the operation of the motorcycle. In all circumstances, the purpose of the journey should be concluded before the expiry of the motorcycle fuel supply at which point the rider will be involuntarily ejected from the motorcycle with little or no prior warning.
