Getting to the Neutral switch under the gearbox???
steveindar
East Africa
How do you get to the neutral switch without removing the whole engine. It's nicely wedged between the bottom of the transmission casing and a frame cross-member. Removing the exhaust and other bits is not enough. Who has what plan?
I'm trying to post a pic, seems not a simple process of just attaching an image...
Remove the rear engine mounting stud.
Lever out the spacer tube.
That will give you sufficient access
Prop up the engine on a car jack ( or similar)
Once you have levered out the cross piece as Mikey says, pop it into the freezer while you do the neutral switch swap. …..and remember to fit a new crush washer ( make sure old washer doesn’t remain stuck to the bottom of your engine…. Don’t ask how I know this!)
Fit new switch, pop the wires on AFTER switch is installed…. Then recover cross piece tube from the freezer and refit. Sometimes they are a tight fit, so the cooling is the best way to get them back in place.
Refit engine mounting bolt, torque to correct figures, remove car jack ( or similar device)
Sit back and have a beer!
