Givi and BMW case mounting adaptor
Bendy toy
Torbay, England
My GSA has the full set of BMW aluminium luggage, which is great but the side cases are bulky for everyday use and the top case rather small.
I also have a large Givi Trekker top case that's handy for the odd night away. But it is BIG with a capital B. The snag is the Givi plate and BMW rack are not compatible and its quite a job to swap them over.
Does anyone know of a plate that can latch onto the BMW rack with Givi lugs on the top side. Alternatively, is there a quick detatch system for the BMW top case rack so I could leave a thinner Givi Monokey plate permanently on the lower rack?
It's only a 10 minute job to fit the universal Givi plate. 4 teeeeny screws and 4 bolts.
Won't the Givi E250 plate do the job?
I had one on my GSA for a Monokey top case.
Dead easy and only about £35.
The GIVI SRA5102 Rear Plate is smart but it's still a bolt on.
I have a Givi plate - the one with the diamond grid pattern. It works well on the BMW top case rack or direct onto the Adventure rack.
The issue is I need to spend 10 or 15 minutes getting spanners doing the job, putting the tools away and probably losing the bolts at some point. I was hoping there might be something that clips into place for a quick swap when I need to use the other case.
Perhaps something can be made..............
Hi there, perhaps something could be made as an interface? here is something I came up with to adapt the OEM rack to suit a vario topbox for a GS.
I don`t expect or wish for you to think that you have to buy something from me (I don`t even make what you need) but its just an idea........
Regards,
mark
www.cymarcbikeparts.co.uk
[/url]
Adaptor Plate with Vario plate fitted by cymarceng, on Flickr[/IMG]
