For Sale Givi Trekker Dolomiti 46
Davey B
Nr Beverley, East Yorks
It's in good condition. (Not used for 2 years as I've moved on since having the Africa Twin) I couldn't quite stomach £40+ for two bits of plastic theat GIVI call a backrest so I used a bit of left over matting stuff and made my own. It ain't pretty but serves a purpose.
I've no idea whether it locks onto a Givi rack as it didn't lock properly on mine so I drilled a small hole thru both and bolted it to the rack (mine was metal). It worked fine and only took about 30 seconds to remove if needed. Again, I'd have had to spend some money or either a new lock or a new metal plate...and I'm a Yorkshireman so....
Anyhow, it's cluttering the garage so it needs to go. They seem to be c £300 new. How about £60 delivered. Seems like a bargain if you're not that bothered about posher bikers sniggering at the backrest...(it even has 2 keys too)
I've replied to the 2nd PM received (I have received 3)
I'll just re-iterate the above. The topbox itself locks just fine. It clips onto a Givi rack just fine. It did not lock onto my Givi rack so I bolted it on with one 4mm x 25mm'ish bolt and nylok nut. This was a simple cheap fix as I left the box on for 99% all the time. It comes with 2 original keys. (I bought the box new c6 years ago)
I ain't asking alot for it (I don't think..there's a 2nd hand Dolmiti 30 on ebay for £156)
