cookie said:could they be different thickness down pipes?
First time I picked up this thread, Cookie has a good point. Are these original downpipes or has one been replaced with a cheapo? There was a lot of thin stainless and chromed pipes about for R series bikes. I had an R100RS which used to heat up its pipes to a lovely cherry glow after a good run, everything was spot on.
If the mixture is correct, timing spot on, no sticking valve gear and the bike runs otherwise O.K I'd certainly have a good look at the pipes. Do they have the same finish and ageing?
