Going to try a Lithium battery
I was in Morocco this time last year on my twenty year old DRZ400. Which has a new LiFo battery. Up in the high Atlas it dropped down to -5 at night.
With frost still on the seat, i turned the bike on and It wouldn't even turn over. The lights were on but no one was home !!
I had to leave it with the lights on for a few minutes. And slowly I could see the lights get brighter and brighter as the battery cells woke up.
Then it was absolutely fine. It's just something you need to be aware of and get used to. And try not to panic about.
If you run an older bike and convert to LiFO, I would say it is mandatory to have a dashboard Voltmeter of some type.
Hmm , 2.5c this morning
5 goes to get it started i did begin to think i'd need the jump pack
but then it occurred to me - if the battery wont accept a charge below 0V how can you jump start one in sub zero conditions
So its running, & the next question is will a 7mile run, put back what it used trying to start this morning ( I suspect not, but lets see shall we)
  • Like
Reactions: JJH
"The idea that the 1200 oil cooled bikes were 'designed' for a particular battery type is, I believe, nonsense. Only when you enter the computer controlled bike era (1200 water cooled onwards) then yes, problems arise...)
I'm far more familiar with battery and charging systems on boats... and simply changing to lithium battery banks from lead acid will cause massive overheating problems with the alternator. The reason being... that lithium chemistry batteries have a very low internal resistance... so they'll pull huge currents, often for long periods of time. The general, 'simple' solution is to put a lead acid battery between the alternator and the lithium battery bank. This reduces the charging current to normal levels.
The other solution is to use Battery to battery charging systems where you can control the alternator load.
For this reason, I use a hybrid battery on my bike... so it has a lead-acid battery and a lithium battery in one unit... charges like a normal lead-acid battery and stops me worrying.
Oh yes it will. JJH
Good lithium batterys have a management pack in the battery, this controls the charging cuircuit to prevent charging / discharging issues
I took the lithium battery out of my hp2 before a trip, beacuse I believed, rightly or wrongly, that jump starting them isn’t straightforward.
For example, I don’t think you can just run jump leads over from a bike with a lead acid battery an the engine
Why ? is it because your have lead acid 12v and not lithium volts ??
Yes u can. JJH
The reason I was given is that the Li batteries are sensitive to voltage and so jumping from a lead acid or another bike, where voltage is variable, can cause a fire.
I didn’t test it, and nor did I want to risk it with HP2.
I did run Li batteries in my KTM EXC’s, and they were fine. As others have said thy do hold their charge for a long time and the better ones have electronics to stop deep discharge, and can be reactivated with a reset button. I used a specific Ctek lithium charger to charge them.
My Nov 2020 Honda Africa Twin Adventure Sports came with a Li battery from the factory. 6 years and 39,000 miles later and it still seems to be fine (kiss of death). Coldest temperature for starting was outside the Strontian Hotel in November a couple of years ago and it had been -3 or 4 overnight and everything including the bike was white. I turned the bike on and put on my helmet and gloves while I waited for the AT screen to boot and AA to kick in (as I usually do) then when I had my helmet and gloves on I hit the starter. It fired up without issue. A few folk on the Africa Twin forum have changed the battery for an AGM one only to find that while it fits the small space it does not quite have the piff to reliably turn the bike over.
