Got a 2013 R1200GS?
Arrived nice and quickly and as described, thanks.
You are the lucky one.
My package was dispatched on the 30th of Jan and arrived in South Africa on the 19th of Feb, thanks to Royal mail and for that I had to pay 20 GB pounds. I can understand why so little manufactured goods are exported form the UK nowadays.
Anyone know where to put the small bits of foam that come with the guards and could you point me to a fitting guide online anywhere?
Just had the black plastic trim off in front of the rads. These guards will not fit at all. And its not because I have the wrong ones. They are miles from fitting over the plastic trim.
I have a 13 plate and am in the same position struggling to fit them. No instructions either so it must me simple or i'm thick - probably.
this is a picture from rugged roads.
Thanks Barnsey, I have seen that and there is no way mine will fit like in the picture.
Edit: I have also left a message on Annette's mobile answerphone. No reply yet :( .
FWIW mine have fitted, rightly or wrongly they've actually gone inside the black plastic bit. I had to bend the lip of the guard slightly on the lower part so it would fit slightly easier.
Mine must have had some installed by the previous owner and removed because it had the same black foam but on the black bit so in the wrong place. The foam needs to go on top of the guard so it sits between the guard and radiator frame to stop it rattling etc.
Looking at the photos they should go outside the black plastic bit. Otherwise only 1 screw holding them in place.
I think Im will be sending mine back.
