Took a day off work this week to sort the S1000R. Really tricky to get the Kliktronic shifter to fit on this one. Ended up using the two M10 threaded lugs on the engine sump and building out from there as the only other option was the engine case. The only place for the shifter to fit and work, so it wasn't in the way of my foot or leg, was to rotate the lever 180 degrees which put the kliktronic unit quite far out and made it rather vulnerable if i drop the bike, so.......... found a company in Russia that make stunt cages and ordered a white one. I actually really like the look of it, which is a bonus. Will take all the shifter bits off, round the edges and paint it up next.
Also fitted some Akra headers. What a difference!! It sounds incredible. All the noise was lost in the cat, as the silencer is essentially straight through.
might say.
