GPS cases & IPHONE cases
cbritton
Suffolk
Dear all,
My company has become a distributor for Arkon products recently. They make many phone mounts and some excellent GPS & iphone cases that mount to handlebars.
GPS cases £21.99 p&p free
Iphone/Smartphone case £17.99 p&p free
Please PM to order and for payment details.
Hopefully the photos attached will work !
Regards, Colin
More iphone case pics below -
Dear all,
Regards, Colin
Hi Colin,
Am i right in assuming these cases are not waterproof...
Hi,
Both are waterproof and feature a robust swivel handlebar mounting for motorcycles or bicycles. They fit all handlebars up to 33mm in diameter. Cases feature waterproof zip, touch through front panel. Included inside is dense foam material to damp vibration and push your satnav/iphone unit against the screen. Both have cable entry ports.
Internal dimensions GPS case - 135mm(w) x 85mm(h) x 28mm(d).
Accepts 3.5" & 4.3" GPS units.
Internal dimensions iphone case - 120mm(h) x 77mm(w) x 20mm(d)
Both cases are removable from handlebar mount but a security screw is included to lock case to mount if preferred.
dont you mean water resistant? i have many items with the same type of zips and i can assure you they are not water proof, having a big hole in the bottom of the case doesnt apear to help either.
not having a go just want to clarify.
Hi Rob,
No I know you're not having a go.
Well you can't go swimming with them but they are perfectly fine for biking motorcycle use.
Regards, Colin.
Electrical Devices Ltd
Hi,
looks good, I note from above that the cases have “cable entry points”, can you confirm that the iPhone case is big enough to allow the iPhone charging cable to be plugged in, whilst in this case?
I ask, as I use my iPhone as a satnav whilst riding, this flattens the battery quickly, the ability to charge on the go (using Burnzillas usb cable) would necessitate having the iPhone plugged in whilst in the case.
Regards,
Timbuktu
