GPS Install on the Scrambler
Baloo2You
Itinerant Jackass
the Grand Commonwealth of Virginia
Just installed the GPS mount for the Zoom XT two on the Scramma Blamma. It seems like everything except changing a tire requires the tank to be removed or at least partially removed. I decided to tap into the GPS accessory plug instead of hot wiring it all the way back to the battery. I was able to repurpose the BMW plug from an old Zumo 550 power cable.
A lot of you guys have probably done this, but it might help someone to find the accessory plug location situated where my big fat finger is pointing. Anyways , ride happy y’all.
Probably a good idea to leave a little slack for placement of the mount. We’re moving it around to suit your needs. The GPS is not gonna live where it is now I will probably shift it lazily to the left.
