GPS memory map adventurer 3500 or Garmin
6821snape
Sheffield England
Hi, loooking for a GPS device for off roading on a bike.:DI want to link up some trails i have marked on some maps. At present i am using a Zumo220 and using waypoint as the start of the track then forget about the zumo till you get to the end of the lane then go to the next waypoint.When i plan the route on mapsource i number all the waypoints in order of the route then import,the waypoints end up in the favourite file its just a bit of hassle :eek as at the end of each lane i need to go to the favourite file to pick the next waypoint.
Is it worth investing in a GPS device i reckon i can get memory map adventure 3500 with uk landranger 1.50000 maps for £270 as the maps would be £100 anyway this seems good value , but not much feedback around.The mount may be bit of an issue.
http://www.memory-map.co.uk/adventurergps/index.php/adv3500.html
or do i go Garmin.Whatever i do i will need the maps and as these are extra to the device it soon starts adding up.:(
Your thoughts please.
