If you're taking the feed from an accessory socket, you don't have to, as the protection is in the controller. If however you are wiring direct from the battery (or via a relay from the battery) an inline fuse is a must. As posted above, the fuse should be positioned as close to the battery as possible. If you don't, you're asking for a fire.
