GPX POI Editor (Webbased)
bertM
Member
Enschede
I have moved this post and thread.
Richard
Let me start by introducing myself:
I’m Bert, and I live in the Netherlands, right on the border with Germany.
I’ve been following this forum for a while; it’s a great place with lots of active discussion, and I enjoy reading along.
I’ve held a motorcycle license for over forty years, though I don’t own a BMW GS myself (though I do get to ride my brother’s every now and then! :-) ).
I do own some other "old iron": a Yamaha TDM, a Guzzi V50, a Jawa 175, and a Vespa GLX (a real "racing loo," as we call them...).
I’ve also been involved with navigation for quite some time—mostly for hiking and cycling—using Garmin devices.
My Zūmo got bricked, so I’m currently using a Montana on my motorcycle.
I spend a lot of time in Slovenia, where I like to use my old Garmin 60CS for hiking in the mountains.
A while back, I started using MyRoute-app (MRA) to plan motorcycle routes.
It’s a great program, though I find its handling of POIs (Points of Interest) a bit lacking.
Since I use POIs frequently—including on my bike computer—I began by managing them in a CSV file.
Later, I moved to Excel and then Google Sheets, setting the latter up to handle the import and export of Google KML and GPX files.
That’s where I keep all my POIs, allowing me to review and manage them.
The downside, however, is that it requires a license and other such requirements.
I wanted to create a program that doesn’t rely on a Google API or any other license, and one that could run entirely within a web browser.
I also wanted to consolidate various functions—tasks for which I previously had to use several different (Garmin) applications.
Furthermore, it was essential that the resulting files would work seamlessly with the Garmin devices I own.
I started working with JavaScript in combination with Leaflet—partly because programming in Google Sheets uses a form of JavaScript, and I already had some experience with that. I now have a program that offers the following features:
- Import of GPX, KML, and Garmin GPI POI files.
- GPX routes and tracks are supported and will be loaded.
- Via points and shaping points from MRA (MyRoute-app) are imported and displayed, including their associated text.
- Multiple GPX files can be imported and merged.
- POIs can be deleted, moved, or added.
- POIs can be transferred between different layers (i.e., between imported GPX files),
allowing you to easily move a POI from Route A to Route B, including all its data.
- Symbols can be assigned to POIs.
- Addresses for POIs can be looked up using OpenStreetMap (OSM).(*)
- POIs—such as 24-hour gas stations, restaurants, or restrooms—can be searched for along a track using the OSM Overpass API.(*)
You can specify a search radius; the distance from the track is saved within the POI data, along with information retrieved from OSM.(*)
Since the Overpass API is not always stable, the program makes multiple attempts across different servers; however, results may vary.
- The entire file can be exported as a GPX file; POIs can also be exported as Garmin GPI (binary) files.
- When imported into Garmin BaseCamp, symbols and fields—such as addresses—are preserved.
- If a GPX file contains multiple routes, they are saved as separate items upon import into BaseCamp.
- Routes can be imported into Kurviger; if a file contains multiple routes, they will be loaded individually.
(*) These features require a connection to an external server; if you do not wish to use this, please avoid these specific options. This is a hobby project—I’m not a programmer—but since others might find it useful, I’ve made it available on GitHub under an MIT license.
There are a few minor flaws, but it’s a "work in progress" and it’s free, so it comes "as is" (no guarantees).
source on Github
web application
Read Me file with details
HI, thanks.
The Imgur files show no content.
Using the web interface,
I imported a route I exported from My Route App and it displays the track correctly but the GPX shows as uncalculated.
I then exported from your web to a merged route, imported it back up to MRA it shows the track exactly the same. So that works. My issue I want to solve is getting a route from MRA to a Zumo XT2 without it going pear shaped or needing to be recalculated. Is this a case of me barking up the wrong tree or how is your software to be used? Or I need to read the read me file :)
Nice bit of work I imported a POI file with 4593 data points and it displays accurately and retains the narrative data for each data point (I agree MRA POI handling is too rudimentary to be useful) I have been able to change the colour of individual data points but not the entire collection. I don't seem to get alternate symbols when I click on the symbols icon. Batch changing of symbols and colours would be useful as would be custom symbols. The only programme I've found that can do this is Basecamp. Well done on what you've produced though. Screenshot of a data point edit.
HI, thanks.
Have a read at this
and this
It might help you to get routes that the XT2/tread app don't mangle. I have a Zumo XT so don't have personal experience of some of the issues.
This is what we get :D​
Imgur access in the United Kingdom​
From September 30, 2025, access to Imgur from the United Kingdom is no longer available. UK users will not be able to log in, view content, or upload images. Imgur content embedded on third-party sites will not display for UK users.
You can exercise your data protection rights without logging in (for example, to request a copy of your data or deletion) using our Help Center request form.
We may request information to verify your identity and will respond within the time limits set by UK data protection law.
We may continue to process limited personal data where necessary and lawful, for example, to comply with legal obligations and to establish, exercise or defend legal claims. Information about how long we keep data and how we process it is available in our Privacy Policy.
If you have questions, please contact us via our Support request form.
Hi
HI, thanks.
Strange, I see the files.. but I am new in this forum and trying to find the right buttons for the images. images can also be found in the source, directory img.
It is correct that you see uncalculated. I only import the waypoint and route points from the original file and not the timesettings. Also time is not calculated whatsoever.
MRA Via and Shaping points make up the route and you will see them as a dotted line. When importing this into a garmin device ( what will have for sure a different map ) will always trigger a recalculation.
The program is made for editing POI files, the track / route is only an aid.
(Seeing your reply I wonder if it is a good idea to put the route/ track in the export….)
My workflow is to load a file and then click a POI, a popup apears with “copy to Layer” and then + New layer ( i see this is in Dutch, will change it ).
You then get a new file ( kopie) where you can put the POI on. You can save it without route and track.
I will add a extra button to have the 2 options te save with and without route/ track. Also scan for more Dutch wordings 😔
Hi
The colours are in Dutch but were easily worked out :D
You got exactly the points I have to work on:
The color change is something I have to work on. It only changes in the Leaflet layer and is not exported (Yet). Basecamp gave me a kick in the A#@,: took me a whole day to get the data correct into Basecamp as all the other programs had no problem. I was SO very happy that I got the data working ;-)
There only some Custom symbols for now in the list: only the ones in the dropdown: You have already some data in the "Name" field, so you do not see the dropdown.
if you have a empty name field on the right there will be arrow with a dropdown. Garmin Names like "Summit" and Restaurant will give custom symbols. I have this not on the marker (yet) like MRA
As it is a browser only application I have to get the symbols from an open source. PM me if you want some Symbols, I will see if I can find them.
Batch changing is a good idea, I have to see if that is possible in Java/Leaflet. As it is browser based I have to store it inside memory, I do not store things on the computer.
SH.... Just changed some Dutch dialogs and uploaded it. Will change it the next time.
Thanks for your feedback Mzokk.
what is a good way to upload screenshots as Imgur does not work...
Most of the code I already had, so I (and AI) made an additional script that does the above.
On the right top there is now an option "Color Known Symbols" if you thick it, this option will be stored in your browser.
If not ticked, It will not change color on loading of the file.
On loading of a file the program will check for know symbols and color them.
Also it will search your "Description" field : if there is a let say "Restaurant" it will fill in the correct symbol and color (has to be tested more).
Colors will not be exported to the waypoints yet, this I have to work out and takes some more time
Symbols can be extended, but therefore I have to see what is available in awsome fonts.
Known symbols can be selected in the POI edit mode in the field "Symbol"
Please can someone explain how to get images on this forum? Imgur seems not to work in the UK, and linking images from Github is not allowed :-(
As pictures say more then words, it would be nice to know
So here is the picture from the color update.
@Mzokk Please explain what you mean by batch exchanging symbols.
Search a POI group and change the name of select POI and then change?
What Navi program uses colored POI?
Hi Bert. I mean something like this. Where you can go from something like this
to this
Or this
With the same data in Basecamp
I currently use POI's perhaps differently than most. They don't tend to be included in routes but I keep Defence Heritage Icons, Dolmen Tombs and public loos on my Zumo XT as Icons at the moment and may visit them if I'm riding past.
On the ZumoXT they appear on the map as highlighted. Those are two Dolmen tombs
I get what you mean, that will be no problem to implement,I think :unsure:
I have started with my Google sheets just to do the same: batch convert POI.
What I can try is make a sort Search and Replace.
I already filter the symbols as you can see in the screenshot in my previous post.
Search "Blue Marker" and replace it in "Battle Tank".
I see you use Google Maps, I have to look how the markers are imported now.
(you can import Google KML already, there is no export yet, but I can add that as I have it already in Google Sheets).
I was already looking at the colored waypoints, this can be done, and some Navigation programs support it (Not Basecamp).
Because of back issues I am not so mobile, so lots of time to play around with the computer...
to be continued
@Mzokk
You got me working... and I added some more
It now supports colors in the GPX:
- If the POI has a color assigned in the GPX, with the import the color will be transferred to the map
- If the symbol does not have a color, but a "Symbol" tag, let say Cafe, the markers get a color.
- If there is a empty symbol field, but in the description like there is "Hotel", the symbol get the right color, and the symbol field is filled.
everything can be edited and will be saved in the export.
This Google My-Maps file:
Converts to this when imported:
Batch convert:
- You can search on symbol names and convert them to another Symbol Cafe --> Bar for example.
I have to do some testing and remove the Dutch wordings. If everthing works, like in basecamp importing ;-( , I will upload the files.
The next thing will be KML import, Google has his own standards...
again to be continued...
Bert
