Hey BuB
If I understand you correctly, you have the housing and the rev and speedo units, but (a) bezzles missing (b) glass missing and (c) rev counter needle missing so you don't know if it works.
Re (a), you can buy bezzles, cost £7 each and part number is 62 11 1 356 676 (or check here
http://www.motorworks.co.uk/bmw/pro...ode=20&partcode=RA&source_code=BA_15_20_RA_70)
Re (b), you can't buy new glass as a separate item I'm afraid. So you have two choices. Either have new items made from glass or perspex or buy a new housing for £100 which will include the main case (but not the back) and the glass, part number is 62 11 1 356 664 (or check here
http://www.motorworks.co.uk/bmw/pro...rtcode=RA&source_code=BA_15_20_RA_70&spPage=2)
Re (c), this is a bit more tricky. The needles often come off. To check if the rev counter is working, how about a needle stuck on the 'nub' with a bit of blue tack? That should show the operation. If it works, you just need to find a needle off pretty much any period rev counter or speedo. This wouldn't be difficult to do, as you could buy second hand from Motobins, Motorworks, etc. But you'd have to buy a complete second hand rev counter just for the needle.
If the rev counter doesn't work, it depends upon why not. If no movement at all, check the spring is in place/not broken just behind the face. If it works but swings wildly, then try white grease on the two white plastic cogs at the back of the rev counter (one cog on the end of the rev counter, the other cog in the housing). If it still doesn't work, you could either try to have fixed or buy a new rev counter unit, part number 62 11 1 356 660 (or buy here for £142
http://www.motorworks.co.uk/bmw/pro...ode=20&partcode=RA&source_code=BA_15_20_RA_35)
Good luck and let us know how you get on
