Just thought I would chuck this into the mix and see if anyone has an idea.
Grip heaters, two settings, is there a way to change the power supply for these settings.
My FJR has an option in the menu to associate a % to the presets! but can't find anything in the manual or anything obvious in the menus and settings.
Found on the last 2 runs out, one just damn cold the other wet, very wet so it saps the heat, The grip heaters just could not cope with it, the FJR with OEM, and the XJR with the Oxford heated grips get to the point that if is almost to hot.
Anyone else found this to be a problem?
Or is thus just a BMW thing.
A few have complained that the heated grips on the LC aren't as good as the previous GS. In the winter, I wear Keis heated gloves, and now find the combination TOO hot!
