Mick
Changing the final drive input seal, removed main nut and castellated ring nut (that holds seal). Struggling removing the compression washer ( to replace) should slide straight off spline but stuck fast. Had to use heat on nuts so might be some locking compound leaked onto washer. Thought about drilling small hole to put a screw in to get some purchase on it and apply heat. Just wondered if anybody has had this problem?
Cheers Mick
Cheers Mick
