stuarte
If you have a GS 1150 with ABS read on, could save you a VERY nasty experience!
Had an exciting problem recently where brakes failed at low speed, nothing there at all, no residual braking, I usually use the front brake only and got it stopped using the back brake, very scary. Intermittent warning lights etc
Took it to the dealers, ran diagnostics, no problem, they were adamant that any ABS failure should leave you with residual braking. Leaving dealer and got an ABS warning light, took it back, agian no fault found.
Ordered a 2nd hand front sensor as the dealer suggested. As I was fitting it I noticed the Front ABS sensor cable had worn through where it passes through a metal clip on the fork stantion.
I can only assume that the sensor was shorting out and making the bike believe the front wheel had stopped and was therefore applying the ABS leaving me with NO brakes at all. This only happened at low speed but when you are coming to a junction it's not good.
