GS 1250 TS Rear Axle Rear Wheel Drive Control Sensor Cover Fitting - Too Loose
Not open for further replies.
Spotcheck Billy
Member
Aberdeen, Scotland
I'm a newbie to this forum and have what is probably a daft question.
The cover for the level sensor fell off. I've got a new one and a new grommet but when I try and fit the cover, (by simply inserting the 'male' part at the bottom of the cover into the grommet), the cover rattles around. Have checked a few guys other bikes and they all seem to be fitted securely. I can't see how else the cover is attached to the bike other than through the grommet. Any thoughts?
https://tinyurl.com/3jktpsev
i would say the cover hooks over the rh end of number 3 and then pops into the rubber grommet
You're spot on.
The cover has little female insets at the top that I hadn't noticed before. At the top of number 3 are two small male lugs so, as you suggested, I hooked the cover in at the top and then into the grommet and it's pretty secure. Many thanks.
